Message |
test voltage at the pump, if it has voltage and a good ground, then your pump is bad. If it has no voltage, test the voltage at the relay (or controller if its a TT), work your way back to the fuse (which you should verify is good first)
------------------------------------------------------------------ 1992 300ZX NA 5 Sp (Dead) 1990 300ZX NA Auto 2+2 (Dead) 1990 300ZX TT 5 Sp (Est. 400 HP) 1990 300ZX TT 5 Sp (Est. 600 HP) 2004 G35 Sport 6MT (DD) |
